96 ram 2wd camber problem
Old Aug 13, 2014 | 03:29 PM
I ram it's Avatar
I ram it
Default 96 ram 2wd camber problem
I have a 96 ram 2wd with a 3" body and 2.5" front coil spacers I'm have a bad camber problem I didn't notice it until I put my bigger tires on and 2 1/2 inch wheel spacers now I see a big difference my bottom of my tire comes out more than on the top I have a negative camber can someone please tell what could be causing this problem
Old Aug 13, 2014 | 04:09 PM
stewie01's Avatar
stewie01
Did you have it aligned after the spacers were installed?
Old Aug 13, 2014 | 06:09 PM
2 1/2 inch spacers? Ouch. Well, at least you have rebuildable bearings in the front...... might want to invest in a couple sets, as you are going to go thru them like water over a cliff.
