Death Wobble???
Old Aug 21, 2014 | 08:43 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by DodgeRam23
the front suspension is all new and the rear end was rebuilt 4 months ago
Please detail out the above.
Front suspension new parts are?
What was rebuilt of the rear end 4 months ago?
The "wobble/shake" > 60 mph started happening when compared to the above work? Before both of them? After front, after rear, after both?
Old Aug 21, 2014 | 09:24 AM
CSDavies26's Avatar
CSDavies26
starts at about 60 and up and the whole truck shakes thru the sseat and the steering wheel, im doing a tune up so that should take care of any misfire in the truck, ive never had a misfiring problem but will look into it
Doing a simple plugs + wires tune-up will not solve a misfiring problem caused by a blown plenum. When your plenum gasket fails, the intake will fail to hold vacuum and you will then experience a loss of engine oil, misfires, and eventually a clogged catalytic converter which will further complicate the issue. Not every plenum gasket fails in the same way and each truck can exhibit different symptoms of the problem...a sure-fire way to check your plenum gasket is to remove the air cleaner and throttle body and take a flashlight and look down into your intake. If there is any oil at all that is pooling towards the back, your plenum gasket is done.
Old Aug 21, 2014 | 06:30 PM
DodgeRam23's Avatar
DodgeRam23
and the rear driveshaft u joints are new
Old Aug 21, 2014 | 06:36 PM
DodgeRam23's Avatar
DodgeRam23
the plenum gasket is okay there is no oil burning and there was no oil that i could see... the front suspesion has new ball joints, u joints, wheel bearing, a new track bar, new gear box, new tie rod ends, as for the rear i put new clutch packs in them after a garage messed up the rebuild, put new axle seals in, made sure axles were un damaged the ring and pinion is in good shape, drive shaft is balanced and have a new rear yoke, the shake starteds to happen after. the front suspension parts were replaced which was around April of this year. i hope i answered everyones questions,
Old Aug 21, 2014 | 07:03 PM
You just hearing banging around over bumps? Or does the truck start shaking, and not stop once it starts? (till you stop, or at least, slow way down....)
If you are just getting a vibration above X speed, rotate your tires, and see if the vibration changes.
Old Aug 21, 2014 | 08:44 PM
DodgeRam23's Avatar
DodgeRam23
no banging, and it starts at 60 and will stop when I leave off but starts when I get on the gas again and ive already rotated the tires and it didn't do anything
Old Aug 22, 2014 | 10:07 AM
How are your brakes? Does the pedal bounce around under your foot when you apply them?
Old Aug 23, 2014 | 10:40 PM
DodgeRam23's Avatar
DodgeRam23
brakes feel fine
Old Aug 23, 2014 | 11:05 PM
That's gonna make it fun to find.....
That leaves bearings somewhere..... or, possibly a misfire that develops at higher RPM?
Old Aug 23, 2014 | 11:49 PM
AtomicDog's Avatar
AtomicDog
Also, consider having your wheels re-balanced and insist that they set the balancing machine so that it requires weights on both sides of the wheel to finely balance them. Lastly, you may have lost a wheel weight due to bumpy roads or improper wheel weigh installation.
