Upgrading Front Brakes
Old Sep 3, 2014 | 08:50 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
You'll be able to use your standard 1500 rotors. That's what I'm running on mine.
Old Sep 3, 2014 | 09:09 AM
Sooper's Avatar
Sooper
Originally Posted by oxymoron29
It would be smart to bring a caliper as well. 1500's had 75mm pistons, 2500 light duties had 80mm pistons and 2500 HD / 3500's had 86mm pistons.
And the 86mm piston calipers, were those the 8800 GVW calipers, and will they bolt up to my brackets and fit my rotors? Which pads should I get with those or does that matter?
Old Sep 3, 2014 | 09:19 AM
1997JollyGreenGiant
Yes, the 86mm calipers are the 8800 GVW calipers. They will bolt up to your brackets and fit your rotors. Just get the pads for the 8800 GVW calipers. That's the same set up I upgraded my 1500 to. I like my brakes quite a bit!
