Wheel backspace offset Dilema, need guidance
Old Sep 8, 2014 | 03:34 PM
jmhd1989's Avatar
jmhd1989
Default Wheel backspace offset Dilema, need guidance
so i ordered a set of steel wheels 17x9 4.50 backspace and -13mm offset. I put them on without the tire to see if they were going to be too wide and boy were they. Stuck out so far and i hate that. I read and thought the backspace was 4.5 on my OE wheels but when i measured after seeing how far they stuck out its actually 5.5 backspace. So i checked and they do not have a 17X8 with a 5.5 backspace so i had to drop back down to 16x8 with a 5 backspace. so this means that it will stick out and inch more due to going from 16x7 to 16x8 and also a 1/2 inch because its going from a 5.5 backspace to a 5. so an inch and a half i think i can live with, but the offset is +13mm which i believe pulls the wheel in closer to the frame making it almost only 1 inch sticking out from stock.
So question is am i correct in my numbers and with it pulling in with the +
13 offest will i rub frame with a 285/75R16? thanks guys i need to figure out so i can do the exchange or return through summit racing.
Old Sep 8, 2014 | 08:34 PM
armynurse's Avatar
armynurse
I've got Dick Cepek Torque rims 16x8" with 4.5" of backspacing, with fairly new FC II tires 285/75/16". I've also got 2" taller springs up front, and a long-leaf 2" add-a-leaf in the rear. It's a good combination/set-up.
Wheel specs: http://www.desertrat.com/products/?id=7283
After reading your email, I went out and had my wife hold the steering wheel at full lock and measured how close the tire was to anything underneath. The tire was just over 2" from the upper control arm (that's the closest it came to anything).
Even with 4.5" backspacing and 285 tires, it definitely does not look like the tires stick out too far. Send me a PM with your email and I'll send you a few pictures of the tires on the truck front/rear/side-view (I'm maxed out on how many I can post on this forum).
Old Sep 8, 2014 | 09:01 PM
Ham Bone's Avatar
Ham Bone
Use photobucket (free) and post the IMG code here as a link then the pic will show up for everyone to see instantly
Old Sep 8, 2014 | 09:50 PM
armynurse's Avatar
armynurse
It's been so long since I messed with photobucket. Let's see if this works (pictures of truck from side, rear, and front as described above).
Old Sep 9, 2014 | 11:31 AM
jmhd1989's Avatar
jmhd1989
thank you so much for the photos, that helps my decision. i agree i don't think those stick out too far at all. i think the 17x9 with the 4.5 backspace pushes it over the edge for me. I wanted to get a 17 and now that i can use 4.5" my options are more. So just to be extra sure going to a 17x8 with 4.5 backspace would still look like yours in the sense of outward length? and thanks again for taking the time to check that and photograph your truck for me, i really appreciate it
Old Sep 9, 2014 | 12:08 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Here are some more pics to help you out.
Helo Maxx 6 wheels -- 17x9 4.5" backspace and -12mm offset
Mickey Thompson MTZ 33s
No rub and sit like armynurse from what I can tell.
Old Sep 9, 2014 | 12:24 PM
jmhd1989's Avatar
jmhd1989
Helo Maxx 6 wheels -- 4.5" backspace and -12mm offset
thanks for the additional photos, are your wheels 16x8's as well?
Attached Thumbnails Wheel backspace offset Dilema, need guidance-img_20110911_161120.jpg
Old Sep 9, 2014 | 12:28 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
ooopsie.
edited the post.
they are 17x9
Old Sep 9, 2014 | 12:34 PM
jmhd1989's Avatar
jmhd1989
ooopsie.
edited the post.
they are 17x9
ok so that is the dimensions of the wheel i ordered, it doesn't look as bad with a tire mounted on it as it did just the rim. so if i exchange for a 17x8 with 4.5 backspace and 0mm offset it would pull it in an inch from your stance correct? Thanks again
Old Sep 9, 2014 | 07:56 PM
armynurse's Avatar
armynurse
I'm wanting to say "Yes"; with 285/70/17" tires on 17x8" rims with 4.5" backspacing it should look pretty much like mine as far as sticking outside the fenderwells.
285/75/16" tires are essentially 33" x 11.5" wide tires (that's what I'm running). 305/70/16" tires are essentially 33" x 12.5" wide tires. 255/85/16" tires are essentially 33" x 10.5" wide tires. Usually 33" tires on 15" rims are 12.5" wide (with a few 10.5" narrow 33" tires for 15" rims). And there are different metric sizes for 33" tires for 17" rims too that vary in width.
Why am I saying this? Be aware when folks tell you they have 33" tires on 16" or 17" tires; they may be 33" tall, but the widths may vary. You might want to ask for folks specific tire sizes when looking at their truck's tires when considering tires/rims for yours. An 11.5" wide tire will look different on a rim compared to a 12.5" wide tire on the same size rim.
