misfire issue.
Old Sep 16, 2014 | 06:13 PM
BrandonBuc'em's Avatar
BrandonBuc'em
Originally Posted by djbucky3
What type of driving are you mostly doing? I found when i am at school (the truck rarely goes over 2k) that it seems carbon builds up. Letting her loose every once in awhile seems to have helped my issue.
i almost never take it above 2400. and thats when im going up hills or beating a ford off the line at a read light lol i dont beat on my truck.
Old Sep 16, 2014 | 06:28 PM
djbucky3's Avatar
djbucky3
Try letting her hit 3k + every once in awhile. These big engines need to run hard sometimes.
Old Sep 16, 2014 | 06:41 PM
Spillage's Avatar
Spillage
Originally Posted by BrandonBuc'em
not to jump off topic here but real quick, spillage, do those long tube headers interfere with your front drive shaft at all? i was told to shy away from long tubes on a 4x4 truck cause they hit on the front drive shaft.
Under harder acceleration from standstill, yes, the front driveshaft rubs the collector.
Mild acceleration from standstill or harder acceleration over ~35mph it doesn't hit.
I have some urethane engine mount inserts I plan on installing to lessen the amount of torquing in the mounts... hopefully this will fix it... if not, the next move is to clock the transfercase.
...Back on topic...
Old Sep 16, 2014 | 06:53 PM
Spillage's Avatar
Spillage
That was me also... but after fitting some mods, and seeing how it really comes to life over 2500rpm, I venture up there every once in a while
Old Sep 16, 2014 | 07:08 PM
BrandonBuc'em
...Back on topic...
very helpful information there. thank you very much.
i plan on doing a good amount of upgrades to this truck. i just started a new job and i have to wait 2 weeks till my first check, so until that time comes im having to pinch as many pennies together as possible. at the same time i cant allow warn or non functioning parts to destroy other parts.
the crank position sensor was suggested to be replaced and i plan on doing so
Old Sep 16, 2014 | 07:18 PM
Spillage's Avatar
Spillage
...the crank position sensor was suggested to be replaced and i plan on doing so
What is the total mileage on your truck?
If you're approaching 100k, most sensors should be replaced (if not already).
All sensors deteriorate over time... some just quit working (obvious failure), others don't do their job as accurately as the once did (performance not at its peak, or some mystery symptom that you can't track down).
Old Sep 16, 2014 | 07:26 PM
BrandonBuc'em
i have 158k miles on my truck and as far as i know thats the factory sensor in there
Old Sep 17, 2014 | 12:34 AM
djbucky3's Avatar
djbucky3
*thread has been hijacked* back on topic gentlemen!
Old Sep 17, 2014 | 12:44 AM
Twmays's Avatar
Twmays
A clogged cat shouldn't cause misfires... I think you're running off in the wrong direction.
Start at the basics: your engine requires 4 things: fuel, air, spark, and compression. Unless you threw a rod, you have compression, and unless you bent a valve or slipped your timing you have air, so...
Misfires are going to be either a) plugs aren't getting spark or b) cylinders aren't getting fuel. Usually no spark.
Your common causes are going to be
* worn/damaged plugs (shouldn't be yours if less than 1500 miles old)
* worn/damaged plug wires, (again, you should be fine if less than 1500 miles old)
* worn/damaged distributor cap/rotor
* faulty coil (all cylinders, not just one)
* faulty crank position sensor (doesn't tell the PCM which cylinder the engine is on so it doesn't think to fire
* after these... It gets weird...
My money is on plug wires or crank sensor. I've seen wires melt to the manifold if they get close enough. Or one just worked its way off a bit... But the random code means it's affecting more than one cylinder or the PCM can't figure out the pattern, so my money is on a sensor or other electrical component.
If you're not getting fuel, it's (almost) got to be an injector problem. If you think it's the injector, swap #1 and #3 and see if the misfire follows it.
As for sensors, I just replaced the throttle body sensors (IAC, TPS, MAP) and ordered a new CPS from rock auto for... $125? Somewhere in there...
There are ways you can test them with a multimeter, and mine all tested "good", but juuuuust barely. So I replaced them. It's amazing the difference it's made.
Old Sep 17, 2014 | 04:16 PM
djbucky3's Avatar
djbucky3
How hard to replace those sensors?
