I did not know that...thanks heyyou ill definately look into those...
Im also looking for 1.92 heads as well...but im still trying to figure out is what kind of porting and what not should I do to increase torque?
Any porting you do will help. Do NOT increase combustion chamber size though. Even simply gasket matching will show an increase. You don't want to hog out the runners though.... low end torque is all about flow velocity, not volume. So the smaller runners (smoothed maybe) will give you that.
