Truck loading up on fuel. Help*
Old Sep 19, 2014 | 06:34 PM
JRod17's Avatar
JRod17
Default Truck loading up on fuel. Help*
I have a 1997 dodge ram 1500. 5.9l v8. Just replaced the keg with the Hughes air gap intake(plenum fix). New IAC, IAT, TPS. Replaced all vacuum lines going to the intake. That being said, my truck will load up on fuel and start to chug after start up. A tap of the accelerator will cause to truck to run at a higher RPM until the excess fuel is burned off. After that process the truck will run fine until shut off And re-started.
*Note* this usually takes place 20-60 seconds after start up.
I could really use some help on this one.
Old Sep 19, 2014 | 06:38 PM
Check temp sensors. You have two.
Edit: At least, you should have two. A two wire, for the PCM, and a one wire, for the gauge in the dash.
Old Sep 19, 2014 | 09:20 PM
JRod17's Avatar
JRod17
Would the temp sensor for the dash gage really need replaced or would just the PCM just be needed? I understand I should probably just replace both at the same time, but I don't see how the gage sensor would cause such a symptom.
Old Sep 19, 2014 | 10:55 PM
Adobedude's Avatar
Adobedude
You might only have one doing double duty on a 97. How many did you remove from the keg manifold?
Old Sep 20, 2014 | 12:28 AM
JRod17's Avatar
JRod17
I removed the IAT (and put in a new sensor) and I have both the single wire and the double wire temp sensor.
Old Sep 20, 2014 | 10:57 AM
Adobedude's Avatar
Adobedude
Sensor going to the PCM is all you care about to get it running right.
Old Sep 20, 2014 | 02:07 PM
JRod17's Avatar
JRod17
I changed out both sensors and I still have the same problem. Would the O2 sensor cause this?
Old Sep 20, 2014 | 03:03 PM
JRod17's Avatar
JRod17
I should mention this problem was going on before I replaced the intake manifold.
Old Sep 20, 2014 | 05:02 PM
O2 sensor shouldn't play a role. PCM doesn't start paying attention to it for a few minutes after initial startup. You can verify that it is/is not the problem, by simply disconnecting it, and see if the problem changes. (if the front O2 doesn't do anything, next, I would plug it back in, and try unplugging the rear O2. See if that doesn't help)
Old Sep 21, 2014 | 02:16 PM
JRod17's Avatar
JRod17
Anybody have any other ideas?
