Cylinder Head Question
Old Sep 20, 2014 | 10:20 AM
renardk764's Avatar
renardk764
Default Cylinder Head Question
Getting ready to install heads and noticed a little surface rust on the sealing surface. Do I need to gently remove that before buttoning her up?
Old Sep 20, 2014 | 10:56 AM
Adobedude's Avatar
Adobedude
I would.
Old Sep 20, 2014 | 11:12 AM
renardk764's Avatar
renardk764
Thanks Adobe! Also I want to check valve clearance. Will I be able to reuse the head gaskets or buy replacements? These are new ones.
Old Sep 20, 2014 | 11:16 AM
frankie_b_jr's Avatar
frankie_b_jr
Replace. You usually have to sacrifice two or three sets minimum to appease the engine gods, lol.
Old Sep 20, 2014 | 11:24 AM
renardk764's Avatar
renardk764
Okie dokie. Will do! Thanks!
Old Sep 20, 2014 | 01:27 PM
AtomicDog's Avatar
AtomicDog
Yes, please make sure that the block and head surfaces are clean. Be sure to use a new head gasket and be sure to torque it to spec using the appropriate alternating bolt pattern as documented in the service manual.
