New Guy here with questions and Problems
Old Sep 24, 2014 | 01:04 PM
  #21
jrcobb1994's Avatar
jrcobb1994
if i put the t case into N and the trans into D will the transmision shift through the gears even though the truck isnt moving
Old Sep 24, 2014 | 01:35 PM
  #22
I dont know.... there won't be a load on it, and the PCM won't see vehicle speed increasing.... may confuse the snot out of it. Of course, yours has a mechanical governor, so, it may not matter. Can't hurt to try it I suppose, but, not sure if you will be able to tell when it shifts.
Old Sep 24, 2014 | 01:55 PM
  #23
jrcobb1994's Avatar
jrcobb1994
i will have to test it a little later tonight, i guess i will let you know what it does. Also i dont know if this will help with diagnosing any problems but my speedometer fluctuated on accuracy somtime it would read correctly then time it would read 10-20mph off. Might not have anything to do with any of my other problems installed an after market.
Old Sep 28, 2014 | 04:39 PM
  #24
jrcobb1994's Avatar
jrcobb1994
I have looked and looked and looked but cant seem to find a streight answer, will at 46rh tranny from a 2wd work in my 4wd. Like it seem all i would have to do is take the tail shaft off and put the transfercase in its place.
Old Sep 28, 2014 | 06:33 PM
  #25
I think the tailshaft housing on the 2wd trans is cast as part of the rest of the housing, so, no. Won't work.
Old Oct 5, 2014 | 06:24 PM
  #26
jrcobb1994's Avatar
jrcobb1994
So i started my hunt for a junkyard transmission, not to necessarily swap into the truck but possibly use for hard parts. Im getting ready to rebuild this transmission and i have a feeling that some hard parts have been damaged. What vehicles can i find this tranny in. I know i can find it in rams with v8s from 94-95, are there any other vehicles, preferably with 4x4 like dekotas and cherokees?
Old Oct 6, 2014 | 07:08 PM
  #27
Dakotas may have it, if they have the V-8, Cherokees as well. Since yours if 4x4, vans and such won't work..... (at least, not for the output shaft, everything else though.)
Where ya at? I have a 46RH sitting in the barn that I have no use for.
Old Oct 7, 2014 | 04:00 PM
  #28
jrcobb1994's Avatar
jrcobb1994
in texas, a bit far from you
Old Oct 8, 2014 | 01:57 PM
  #29
Ouch, yeah, that would be killer on shipping.....
Old Oct 8, 2014 | 02:36 PM
  #30
jrcobb1994's Avatar
jrcobb1994
yeah...
