burning oil after pelnum plate repair
Old Sep 26, 2014 | 08:26 PM
btyson35's Avatar
btyson35
Default burning oil after pelnum plate repair
we just repaired the plenum plate with the huges repair kit and now we still get some blue smoke when going down the road but not quite as bad as before im working on the oil pressure issue changing the pick up tube screen it was clogged putting pan back on tomorrow hope that fixes that problem any ideas on where other oil is buring tho
Old Sep 26, 2014 | 08:33 PM
AtomicDog's Avatar
AtomicDog
How is your PCV valve? Replaced it lately? Lastly, how many miles are on your motor?
Old Sep 26, 2014 | 10:13 PM
SilverSS's Avatar
SilverSS
checked compression?
Old Sep 27, 2014 | 06:42 PM
It's Me Patt's Avatar
It's Me Patt
ditto above, PCV (From dealership) and a dry/wet compression test as you want to know how your piston rings are. Also high miles might = valve seals replacement..You're not burning oil because of the screen..
Old Sep 30, 2014 | 07:03 PM
btyson35's Avatar
btyson35
shes just rolled over 200 and never changed pcv valve either im betting on rings tho
Old Oct 1, 2014 | 06:57 AM
It's Me Patt
Changed mine pcv from AA. The most expensive pcv at advanced is $7.99 use code p20 for 20% off
But let us know if you do the comp test what the #'s are.. As for the blue smoke that's making me think pcv, valve seal(s), rings
Old Oct 1, 2014 | 09:07 AM
Ham Bone's Avatar
Ham Bone
Does the smoke go away after a Little while?
Rings are probabbly a lil worn at that point. But your valve seals are likely gone. I know i burn a decent amount of oil after start up and the engine has been sitting for a while. But it clears up and then doesn't seem to burn any at all.
If you're having oil pressure problems it seems to point to your bottom end on its way out.
