Crank sensor grommet trouble!
Old Sep 28, 2014 | 05:01 PM
Leeflaig's Avatar
Leeflaig
Default Crank sensor grommet trouble!
Hello all,
So, I've sought advice from this site for years, but never had to post a question. Today I pulled out my old crank sensor to replace it, and noticed the rubber grommet holding it in was pushed halfway in the opening. I tried to snag it out, unsuccessfully, and the GD thing fell into the opening. Cannot for the life of me get to it, or feel where it may be in there.
What the hell do I do!? Do I 1...get a new grommet, start it, and hope for the best? Or 2...am I spending a ton of time pulling the engine apart? If 2, where do I start?
Lee
99 1500 5.9 4x4 POS
Old Sep 28, 2014 | 06:26 PM
Pull the starter motor, and then take off the inspection plate, the grommet will probably just fall out at that point. (disconnect the battery.....)
Old Sep 28, 2014 | 07:19 PM
Leeflaig's Avatar
Leeflaig
Does it matter that my starter is on driver side?
Old Sep 28, 2014 | 09:41 PM
That's where its supposed to be. But, it has to come off to get the inspection plate off.
Old Sep 28, 2014 | 10:30 PM
BackwoodsRam's Avatar
BackwoodsRam
+1 to hey you, the only thing the grommet could be sitting on is the torque converter. If its not sitting in the bottom of the bellhousing then use a large screwdriver to turn the TQ a little and it should fall right out,
