2001 Ram 5.9 Surges Only at Low Speeds and Low RPM
Hey guys,
I read through the transmission diagnostics and have a few things to check, but I figured I would post this in case anyone had this issue and has a quick answer for me.
When the truck is cold, and I am accelerating in first gear at 5-15mph, while holding a stable throttle input, the truck will surge slightly. If I put my foot down it clears up, and it seems to go away once it's warmer, although today I did notice it doing it after a good bit of driving. Also the very first 1-2 shift seems a bit harsh.
It has gotten progressively worse, with the first symptoms starting a couple months ago, it becoming consistent in the last few weeks, and today it gave me the first symptom when warm.
I know the fluid level is a little high, so I am going to pull some of that back out, but I would imagine if it was frothing that it would be symptomatic at higher temps, not when everything's cold right?
Thanks in advance
Thanks in advance
Popped a code on me today. The Torque converter clutch overdrive solenoid code. I did a little research and it appears that can be caused by a pretty wide variety of things.
The trans shifts smoothly from gear to gear, it's just that little hesitation that's becoming a little more frequent and now this code. I'd suspect a TC issue but I'm not sure how to diagnose that.
