Differences between Dana 60 and Dana 60HD rear differential?
Old Oct 7, 2014 | 10:47 PM
AtomicDog's Avatar
AtomicDog
Default Differences between Dana 60 and Dana 60HD rear differential?
Well, the disc brake rear differential I recently picked up looks to be a Dana 60 HD out of a 2001 Dodge Ram 2500 4x4. After pulling the inspection cover off, it looks like the pinion bearing failed. The 3.55 ring and pinion is broken up, along with the spider gears. I'm planning on installing a good used 4.10 ring and pinion in it, along with all new bearings, seals and a Power Lock unit. The unit I'm going to remove is a drum brake Dana 60 rear with 3.55 and 30 spline Power lock.
Does anyone know the differences between a Dana 60 and a Dana 60 HD?
Old Oct 7, 2014 | 10:52 PM
Ham Bone's Avatar
Ham Bone
uhhh Idk if i have a 60HD but i got a 60 out of a 02 2500 4x4 with disc brakes.
Not too sure if they are the same but as i recall when i pulled the BOM it looked like a typical 30 spline dana 60 to me
not much help there......
Old Oct 7, 2014 | 11:06 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
60HD is distinguished by having more webbing on housing and a very clear stamp of HD.
Larger spindles for accommodating 35 spline shafts but some still had 30s.
Those are the top differences.
Old Oct 7, 2014 | 11:32 PM
Ham Bone's Avatar
Ham Bone
listen to this dude
Old Oct 8, 2014 | 07:50 AM
AtomicDog's Avatar
AtomicDog
Thanks for the added info. I'll pull an axle shortly to see if its a 35 or 30 spline axle. That fully dressed differential sure is heavy!
BTW, it looks like the inspection cover is deeper than a standard Dana 60 inspection cover to allow for more oil capacity.
Old Oct 8, 2014 | 10:16 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Put up a picture of the 60HD stamp on the webbing.
Carrier bearings most likely will be larger that std 60, while everything else is std 60 parts. Of course getting the BOM would be the story teller assuming no mods/changes done to it.
Old Oct 8, 2014 | 11:28 AM
Ham Bone's Avatar
Ham Bone
I think finding the BOM on some of the weirder Dana models can be a real challenge.
I found my rear in the database easy.
But my front 60 did not exist according to spicers website. Or I could just not find it.
However, quad 4x4 listed under their site in the Dana 60 section.
It is definetly the place to start with.
Old Oct 14, 2014 | 09:22 AM
tweeker909's Avatar
tweeker909
Crazy talk asking for pics.
Old Oct 14, 2014 | 10:15 PM
AtomicDog's Avatar
AtomicDog
I plan to provide a photo, but just hadn't had a change to take it just yet. I did get a moment to pull an axle and it is 30 spline.
Old Dec 8, 2014 | 03:19 AM
ClubCab5.9's Avatar
ClubCab5.9
Still waiting for them pics.
