Excessive oil usage
Old Oct 10, 2014 | 04:49 PM
Steve111's Avatar
Steve111
Default Excessive oil usage
1997 magnum pickup with 5.2 engine,112000 miles. Does not smoke, could this be the plenum or does that not apply to this engine?
Old Oct 10, 2014 | 11:50 PM
sam3293's Avatar
sam3293
Look through your throttle body into the intake manifold look for oil deposits. My 5.2l burned 5.2litera every 1000 miles when it went bad
Mine didn't smoke either even with the constant burning.
Old Oct 10, 2014 | 11:57 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
How about stating an actual amount that you think is "excessive"?
A quart over a standard 3K oil change interval is nominal. You have low miles, but that doesn't mean you got some crap going on.
Read the sticky thread about the Plenum.
Get a new PCV valve from the dealer.
Old Oct 11, 2014 | 09:24 AM
cjantczak's Avatar
cjantczak
i used a quart of oil every 1000 miles when my plenum was bad and it also pinged of course. never smoked, and didnt have power lose tho.
Old Oct 11, 2014 | 03:05 PM
Steve111's Avatar
Steve111
Default excessive oil usage
Quart of oil 160 miles
Old Oct 12, 2014 | 08:03 AM
sam3293's Avatar
sam3293
Did u look through your throttle body? Sounds like plenum. It's very simple take off air intake. Look through throttle body with flashlight.
