Most Critical o2 Sensor to Change?
I had a smog shop fight me back in Ca because of me not having a post cat but when I checked my stock exhaust to see if there was even wiring for it, it wasn't there. With my 95' I only had a single cat and a single O2 sensor, I know that the 2500 gassers had to cats in each manifold and another one before it headed to the muffler and had a total of 4 O2 sensors. I am assuming that 2500 exhaust systems transferred over to the 1500 as California implemented more laws in the late 90's.
cali emission trucks '01+ have 4 sensors... two precats, monitored upwind and downwind, and then the Y pipe leading to an UNMONITORED bigfatnasty cat.... the big fat nasty cat can disappear and the engine/pcm has no clue...
cali trucks are actually much easier to run true dual or H/X pipe duals on for this reason, which I highly recommend because that Y pipe is the issue.
er...uh... maybe...
those big cats breathe pretty good... and.. they run hotter than the actual exhaust that passes through them, creating an area of low pressure that drafts exhaust pulses out of the collector- exhaust is ALL about scavenging the pulses instead of letting them cool too quickly and creating barriers the pulse behind it has to bust through (creating back pressure.... back pressure is BAD.. scavenging is GOOD)...
the REAL obstacle in OE exhaust is the Y pipe... get rid of that thing... the cat behind the Y actually helps clear the exhaust from the collectors and Y.. if you really want it to breathe right, keep the kitty (or replace it with a high flow) and get the eff rid of that Y pipe.
it isn't so much as having the y-pipe that was the problem, it was the crappy design on the 99 and older trucks. (two down pipes into cat, major restriction, there was a pic around here at one point) The 2000 and up trucks redesigned the exhaust, so the pipes actually come together first, and then its a single inlet cat. Flows a lot better.
Do you have california emissions on your truck??
Not all 2500 had 4 o2 sensors. Standard had 2 the heavy duty's had two per side(duel cats). Cali seems it had them on everything. That's good because most people that run duel exhaust only monitor one side. My plan is to run long tubes into two cats X pipe into twin mufflers out the back.
