97 RAM 1500 heater problems
Afternoon all!! Similar heating problem
97 ram 1500, AC blows really cold, fan blows strong, when I switch the dial from cold to hot I hear the ‘knock’ from the door closing both ways, both pipes running to the heater core are HOT! The inlet is too hot to hold and the outlet just slightly cooler.
Motor never overheats, sits dead centre on the gauge..
when the motor is upto temp and I have the heater dial all the way hot it’s max 45°!
could this still be a heater core problem even though both pipes are hot?
Forgive me is this is wrong but I thought any problem with the heater core would cause the outlet pipe to be considerably colder than the inlet?
cheers
cheers
I am having similar problems with my 99 v10. Very little heat coming out. My engine seems to run relatively colder than most ram engines. I have only gotten the temp up to half way one time and that was pulling a load in 107° heat on bad plugs and after running like that sitting in traffic for a minute. Once I got going it cooled down again. I can’t seem to get much heat out. Air volume is good, blend door is working good, no vacuum leaks, flushed the core out, re filled the core before Re installing the hoses and nothing. Im at a loss!
