please help
Old Oct 28, 2014 | 05:41 PM
devildog1187's Avatar
devildog1187
Default please help
Please help I have a 2001 dodge ram 4x4 5.9 the check engine light came on an threw a code saying engine staying cold to long so I went to swap thermostat an before I put the new one in I checked the old one ..I boiled water an dipped it in an put in cold water an it is doing exactly what it's suppose to do ... so if it's not my thermostat what could be my problem an thanks for the help
Old Oct 28, 2014 | 06:52 PM
2bit's Avatar
2bit
It might be sticking part way open sometimes. Clear the code and see how the new one works. Could be a bad sensor? Check battery connections and any ground wires you can find.
Old Oct 28, 2014 | 10:23 PM
devildog1187
Thanks !!
Old Oct 29, 2014 | 02:50 PM
At what temp does the thermostat start to open? That code is fairly common for folks that have gone to a 180 thermostat.
Old Oct 29, 2014 | 05:54 PM
devildog1187
Yea the thermostat that was in it was a 180 sso I changed it to a 195
Old Oct 29, 2014 | 06:03 PM
diverjer's Avatar
diverjer
I believe the 195 is what they come out with, while changing water pump with small leak, I put in new thermostat (the old was working alright, just was working in the general area). Now I notice it is running a little cooler, so there must have been a something hotter in there. So folks say they run better when hotter, I don't know, just went with standard.
