Splitting the transfer Case
Old Nov 4, 2014 | 04:21 PM
jmhd1989's Avatar
jmhd1989
Default Splitting the transfer Case
When i have the transfer case out to do the trans and transfercase seals i want to re-rtv the t-case halves. my question is can you crack the t-case without having anything move? is it as simple as undo the exterior bolts break case in hlaf re-rtv then reseal? or once i crack it in half springs come out flying and sh**
Old Nov 4, 2014 | 04:34 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
There aren't things that will let loose, however, there are things to keep track of such that it's not a "unbolt, lift, clean, apply rtv, rebolt, etc."
So here's one link to enlighten you amongst the many out there. Quite a few Youtube vids too.
http://www.4wdmechanix.com/NP231-and...ld-Part-1.html
Old Nov 4, 2014 | 05:41 PM
jmhd1989's Avatar
jmhd1989
that is very helpful thank you. it doesn't look like the photos in that link had any rtv sealant on the case halves, is there no need?
Old Nov 9, 2014 | 10:08 PM
Sheriff420's Avatar
Sheriff420
A link to page two is at the bottom of the page. The transfer case would leak if there wasn't any sealant.
