Viper Rocker Arms on 5.2/5.9?
operating range is from 1k-5k, so id say its pretty close to an rv cam. rv cams are idle to 5k.
it has a .480 max lift with 1.6 rockers, .510 max lift with the 1.7s.
its .212, .218 at .050, but i believe its a bit more with the 1.7s.
i really like this setup! the video i posted is from when i had longtubes, and a complete 3" exhaust. magnaflow high flow cat, and an slp loudmouth II muffler.
doesnt sound nearly as good with factory manifold, jegs offroad y, and a dynomax 3" catback.
I replayed that clip many times over... I love it.
What was so pleasing was the fact that the setup is right around what I have planned.
The cam I have in mind is Comp Cams 20-744-9
206°/212°@.050"
.301"/.301" Lobe Lift
.480"/.480"@1.6:1
.512"/.512"@1.7:1
112°LSA
700-4800RPM
As a side note, the SoCalDodge "Sausage Cam" that was thought to be "it" for these engines is;
206°/210°@.050"
.318"/.319" Lobe Lift
.508"/.510"@1.6:1
112°LSA
206°/212°@.050"
.480"/.480"@1.6:1
.512"/.512"@1.7:1
112°LSA
700-4800RPM
206°/210°@.050"
.508"/.510"@1.6:1
112°LSA
that cam is like a RV cam right?
