Electrical problem.. tail lights
Old Nov 30, 2014 | 12:55 PM
tmiller_48's Avatar
tmiller_48
Default Electrical problem.. tail lights
I am having a problems with my right tail light. When I use the blinker with the headlights off, it will work. However, when I turn the headlights on, the it will act like I have the hazards on and the reverse lights also will flash. It is only a problem with the right tail light. When I use the left side, it works like it should. Any ideas? thanks
Old Nov 30, 2014 | 01:14 PM
moe7404's Avatar
moe7404
if i remember right on the older trucks ALL electronics gong to the rear, goes throu the turn signal plate under the steering wheel. but dont know about the newer trucks. if i remember right.
Old Nov 30, 2014 | 01:19 PM
Reverse lights don't.....
Got a trailer harness? Try disconnecting that first......
Old Nov 30, 2014 | 06:20 PM
redneck_ram's Avatar
redneck_ram
trailer harness was the culprit for me. ended up being too much resistance in the wires. spliced in some new wires, and its as good as new!
