98 ram a/c
Old Dec 4, 2014 | 09:36 PM
clintbdu's Avatar
clintbdu
Default 98 ram a/c
compressor seems to be howling, will I gum something up if I put a non a/c belt on and drive for a little while? or should I change comp or just clutch? 5.9 4x4
Old Dec 5, 2014 | 06:48 AM
982500's Avatar
982500
I can't see running a non A/C belt is going to cause any problems. Do you know what is howling? Is it inside the compressor or is it the clutch? I would just change the clutch if that is the issue. Not sure what you think would gum up.
Old Dec 5, 2014 | 07:06 AM
What would you "gum up"?
Old Dec 8, 2014 | 06:06 PM
JSTMoto's Avatar
JSTMoto
If you bypass the compressor with the belt, I would also unplug the compressor clutch from the harness.
I recommend you watch the two videos by this poster on YouTube. Should help you understand the system as his failure sounds similar to yours! I like his channel and diagnostic reasoning. He's a normal guy who is down-to-Earth. He has made a good set of videos for our trucks.
