U Joints or Wheel Bearings?
Old Dec 5, 2014 | 10:28 PM
wymore92's Avatar
wymore92
Default U Joints or Wheel Bearings?
I have a 97 dodge ram ext. cab 5.9L, today I was driving down the e way and had the cruise at 70mph, when I started to go around curves or even slightly turn the steering wheel I can hear something that sounds almost like a fast pace knocking sound and can some what feel it at my feet in the floor board. Its only when I give the wheel a turn in either direction as soon as you straighten it back out the noise disappears. I'm guessing it is maybe the front axle u joints going bad or maybe even possibly the wheel bearings. But I know normally when a wheel bearing goes bad it sounds like more of a howl, and would make that howl noise if you were going straight or not. Any ideas??
Old Dec 6, 2014 | 12:33 AM
Ram Driver's Avatar
Ram Driver
I would check the wheel bearings first, especially if there original with lots of miles on them.
Old Dec 6, 2014 | 09:31 AM
AtomicDog's Avatar
AtomicDog
Need to check them both - it could be either or a combination of the two.
Old Dec 7, 2014 | 12:09 AM
motorboatinjesus's Avatar
motorboatinjesus
It's fairly straight forward. You need to get underneath your truck and see what is loose/rattling. Takes 10 minutes max
Old Dec 8, 2014 | 07:01 AM
onegoodmason's Avatar
onegoodmason
When you inspect it , don't overlook the control arm bushings , swaybar frame bushings , endlinks or shock bushings .
