A good front u joint
Old Dec 16, 2014 | 08:29 PM
sam3293's Avatar
sam3293
Default A good front u joint
So I have replaced the u joints on my truck three times within the past two years. I purchased the auto zones brand duralast gold so I keep getting a free replacement but I'm thinking they should last longer. My truck has about a 6-8in lift its a little hard to tell as I didn't initially lift it. Anyone know a good brand that won't make me replace it as often? It's only in 4wd when I plow my driveway or it's snowing very bad which is maybe 3times a year.
I know moogs good for steering parts not sure about u joints.
Thanks
Old Dec 16, 2014 | 08:48 PM
Forcer's Avatar
Forcer
Quick question, how do you install them?
Old Dec 16, 2014 | 09:41 PM
sam3293's Avatar
sam3293
U need a u joint press or similar looks like a big c clamp pushes them out and installs them. If it's your first time u might break one on installation but it's way cheaper then a shop. There are inner clips that need to be removed before the u joint can be pressed. It's fairly easy separating the hub takes a while until you figure out that u can use the power steering as a press which is a very helpful tip. YouTube should have some videos.
Old Dec 16, 2014 | 09:53 PM
Ham Bone's Avatar
Ham Bone
He was probably asking how you install them specifically because it could be the root of your problems.
Old Dec 16, 2014 | 10:00 PM
sam3293's Avatar
sam3293
Oh well that makes more sense. But they don't bind and I'm careful with the needle bearings to make sure they are in place. They work fine for a while but then just go bad.
Old Dec 16, 2014 | 10:01 PM
Forcer's Avatar
Forcer
Sorry meant to say HOW *DID* YOU INSTALL THEM.
I used the most expensive grease-able ones that i could get( I was younger/dumber) in my old axle they lasted for some time (5ish years)never was hard on it in 4wd though. They did give up shortly after last year while snow plowing.
The reason i asked how did you install them was because I've heard of to many people complaining about brand A and brand B only to find out that they hammered them in. (Didn't use a press)
Old Dec 16, 2014 | 10:02 PM
Forcer's Avatar
Forcer
haha yea I'm slow at typing
Old Dec 16, 2014 | 10:08 PM
sam3293's Avatar
sam3293
These aren't greasavle at the time I just bought whatever autozone had never really looked or searched for better options. Which ones do you use forcer?
Old Dec 16, 2014 | 10:20 PM
Forcer's Avatar
Forcer
I just did an axle swap, but didn't change the joints at the wheels. I did however change the ones in the drive shafts, the rear so far waiting on a new yoke for the front drive shaft. I using a combination of Moog and precision grease-able u joints. I personally think grease-able is better just remember to get them during your oil change.
Old Dec 16, 2014 | 11:20 PM
sam3293's Avatar
sam3293
Yep well I currently have my steering parts all grease able and I grease them every 1500 miles
