Well, I did the upper and bezel with replacements from LMC and had to remove the entire dash from its mounting (but not from the truck) so I know what it takes to replace it. Most of the underneath is removable: glove box, kick panel, cup holder, ABS box, etc. So those can be picked somewhere but the inner frame itself is going to be hard to find. What you'll probably have to do is find a complete dash from a donor and R&R everything to yours. What is the problem? Is it all cracked inside?
The inner dash is completly broken, i cant attatch a bezel or the top piece to it... everything is pretty much zip tied.... i dont know where i can get one...
