fan clutch issues?
Old Jan 5, 2015 | 01:59 PM
viper405's Avatar
viper405
Default fan clutch issues?
The fan on my 99 ram 1500 is always on full tilt, even after it has warmed up. I had the fan clutch replaced but it's still always on. I know it shouldn't be like that because ive never heard another ram that sounded like a city bus all the time. Before I had the fan clutch replaced, the old one would sometimes let go when it was very cold out (like 10 degrees f) but now it doesn't even do that. What's the issue?
Old Jan 5, 2015 | 10:11 PM
Ram Driver's Avatar
Ram Driver
It shouldn`t sound like that all the time, my 2000 ram is very quiet, as yours should be, in cold or hot weather.
Were are you getting your replacement fan clutch from ?, what brand ?.
Sometimes these trucks can be very picky when it come to some parts, so you might want to get a fan clutch from a dealer. It will be a bit more expensive, but it will be a true dodge OEM part.
Old Jan 6, 2015 | 08:10 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I put this one on my truck and hadn't had any issues:
http://www.summitracing.com/parts/hd...model/ram-1500
Old Jan 6, 2015 | 11:45 AM
bjpomeroy's Avatar
bjpomeroy
Sounds like you got another bad one. Not uncommon.
Old Jan 6, 2015 | 06:12 PM
viper405's Avatar
viper405
I got it from belle tire, I can't see what kind it is though. If its another bad one what am I supposed to do? I had a hard time convincing them something was wrong to start with
Old Jan 6, 2015 | 06:21 PM
viper405's Avatar
viper405
How freely does your fan spin by hand? My dads durango fan will keep turning a little if he pushes it, my truck has a lot more resistance, it does not spin at all after I let go
Old Jan 10, 2015 | 12:34 AM
Nate_rs's Avatar
Nate_rs
I replaced mine a couple times trying to get it to quieten down but it wasn't having it. Just ended up doing an e fan conversion.
