aftermarket wheels
Ok im looking at the American racing Baja 172 16x10 now here's where I needsome help what backspace I've been told 4.5 ok do I need a -00mm or a -25mm very much need a good dodge 4x4 wheel tech so I don't by the wrong
Wheels ill be running 305/70r16
All I am seeing for those wheels with a 4.52 backspacing is -25mm offset.
Offset is calculated.... its the distance from the wheel centerline, to the mounting surface. Difficult to have the same backspacing, with different offset, on the same size wheel..... A 00 offset should be close to 5" backspacing....
Ok great I am not a wheel guy ok so the wheels I'm wanting 16x10 would work good and have a wider stance Now hub centric I need to ask bout that this wheels have the center
cap that loads from the back scratching my head on this don't want all the weight on just the lugs
If your truck aint lifted, your tires will most definitely rub. I have experienced that one first hand. I know at least 305s will rub on an 8 in rim, i would hate to see the rub on a 10 in one.
