damn it!!!! brake & abs hell
Old Oct 26, 2005 | 08:28 PM
Jman1's Avatar
Jman1
Default damn it!!!! brake & abs hell
well.... it's been 2 months now... i still can't fix the abs and brake light..... comes on right about 40 mph..... changed the rear sensor twice..... may actually have to bring it to the dealer..... ANYone with another idea???
Old Oct 27, 2005 | 02:08 AM
2big2dodge's Avatar
2big2dodge
Default RE: damn it!!!! brake & abs hell
is there any leakin at all around the drum? could be ur wheel cylinder went out. i had one do that bout 3 weeks ago. it was pretty easy to do too. just a suggestion.
Old Oct 27, 2005 | 01:39 PM
steve05ram360's Avatar
steve05ram360
could be the tone ring in the diff is damaged.
Old Oct 27, 2005 | 07:08 PM
xsputts's Avatar
xsputts
Isn't there another sensor up by the transmission or transfer case?
Old Oct 27, 2005 | 08:09 PM
94Champ's Avatar
94Champ
I'm not familiar with your previous post on the problem you are having, but looking at my factory repair manual for 94 rams [yours may be different]with ABS RWAL they have a rwal electronic control module under the dash by the heat ducting on the passenger side that the rear sensor you replaced sends a signal to directly.The module also stores codes that can be read with an scanner or the manual also says to ground the RWAL diagnostic plug and the ABS lite in the cab will flash for appropriate code-I have never tried this or even know where the diagnostic connector for the ABS is so I can't recommend it.The interesting thing tho is one of the codes is "brake switch always on.RWAL [ABS] lite comes on when speed exceeds 40mph" as printed in my factory manual.I do know the brake switch has 3 different circuits on my truck , not sure on yours,so you may want to check that switch as that code sounds like that describes what you are experiencing,just a thought.Good Luck
Old Oct 27, 2005 | 08:25 PM
2big2dodge's Avatar
2big2dodge
oh your good 94 you are good...
