help transmission issues!!
Old Mar 5, 2015 | 08:54 AM
rudun71@gmail.com's Avatar
rudun71@gmail.com
Default 98durango 4wd 5.2 44re transmission problems
I just had transmission rebuilt and swapped a new msain valvebody in there and it's still not shifting right I have no overdrive have to manually shift and its throwing codes p0753,p1763,p0713
Old Mar 5, 2015 | 10:07 AM
Take it back to where you had it rebuilt.
Old Mar 5, 2015 | 10:14 AM
rudun71@gmail.com
They basically told me the rebuild doesn't cover electrical. I also tested the mechanical side and it shifts through the gears fine
Old Mar 5, 2015 | 10:16 AM
Did they replace any of the electronics when they did the rebuild?
Old Mar 5, 2015 | 10:35 AM
rudun71@gmail.com
So I'm pretty sure they didn't change any solenoids or pressure switches
Old Mar 5, 2015 | 10:36 AM
rudun71@gmail.com
No they did not
Old Mar 5, 2015 | 10:52 AM
P0753 Trans 3-4 Shift Sol/Trans Relay Circs
P0713 Trans Temp Sens Voltage Too Hi
P1763 Governor Press Sens Volts Too Hi
Try Unplugging the 8 pin connector again. See what kind of behavior you get when you shift manually. If everything works good that way, think I would be real tempted to simply replace ALL the electronics in the trans.
Old Mar 5, 2015 | 11:36 AM
rudun71@gmail.com
The wires on the connector are stripped back way too much I'm gonna fix that while I'm at it
Old Mar 5, 2015 | 12:21 PM
That may be the whole problem. Pressure sensor, (which is also the temp sensor) only wants five volts. If it is getting 12..... well, that makes it unhappy.
Fix the wiring first, see if all your problems don't go away.
Old Mar 5, 2015 | 12:47 PM
rudun71@gmail.com
I'll post the results when I'm done
