46RH aluminum shavings?
Old Jan 25, 2015 | 07:02 PM
BigPip's Avatar
BigPip
Default 46RH aluminum shavings?
I picked up a used trans the other day and when I went to inspect it I found aluminum shavings. I have found that this could be considered normal wear, governor including the piston and a few other parts. Since I am semi-new to repairing trans, is there any advice where I should look to find where the aluminum is coming from or just freshen in up, clean it out and slap it in the truck?
Old Jan 25, 2015 | 07:06 PM
newman1367's Avatar
newman1367
aluminum shavings is not normal, you'll have to tear it down completely and see where they came from.
