Ram Models?
Old Jan 28, 2015 | 07:37 PM
Spillage's Avatar
Spillage
I think "Sport Only" applies if made after May 30th, 1998.
Old Jan 29, 2015 | 05:08 PM
wymore92's Avatar
wymore92
Okay so here is another question. Recently after I start the truck and wait a few minutes the truck starts to idle rough and make a sucking noise. If I hit the gas it picks back up and then runs normal for a bit. Going down the road it runs great only when it's sitting it does this. It's got new plugs, wires, cap, rotor, TPS sensor. I just changed the tps sensor today being I thought that was the problem since it pulled a code for it, bit still has the problem. Need help
Old Jan 29, 2015 | 08:01 PM
How old is your O2 sensor? Fixed the plenum yet?
Old Jan 30, 2015 | 06:37 AM
wymore92's Avatar
wymore92
My plenum seems fine, 02's are original to my knowledge so getting pretty old
Old Jan 30, 2015 | 09:37 PM
Probably time for new ones then.
Old Jan 31, 2015 | 12:23 PM
Ramman18's Avatar
Ramman18
Sounds like bad o2 sensors. Get the factory NTK from rockauto.com
Old Feb 1, 2015 | 08:40 AM
wymore92's Avatar
wymore92
I never would of thought that just o2s would cause this. The truck does not have a cat, the previous owner cut it off. So looks like it's time to put one back on and get both new o2s.
Old Feb 1, 2015 | 09:56 AM
Front O2 plays the biggest role in how the engine runs. The cat isn't actually "required" to make things work right... its just an emissions piece. Put a non-fouler on the rear O2, and the PCM will be happy. (My cat is punched out, no non-fouler on the rear O2, but, the PCM has never whined about it.)
