no spark or gauges
Old Feb 3, 2015 | 08:03 PM
2015ram's Avatar
2015ram
Default no spark or gauges
I have 1999 dodge 1500 5.2 4x4,i pulled the engine and had it overhauled,put the engine back in an I have no spark,no gauges,it says no bus in the odometer,everything worked fine before I pulled the engine,i'm leaning toward a ground wire not on or in the wrong place,any ideas?
Old Feb 3, 2015 | 08:06 PM
There are a BUNCH of ground wires.... The two right up by the power steering pump are the most important. There is also one on the back of each head. Make sure those are all in place.
One of the usual victims of an engine or trans swap, is the crankshaft position sensor.... it hangs out behind the passenger side head, down on the bellhousing. They generally get thumped, or crushed when the engine is put back in.... (or, simply forgotten.....) It's a pain to get to, but, you need to check it. Also, make sure no wires got pinched between the engine and trans.
Welcome to DF!
Old Feb 3, 2015 | 09:48 PM
2015ram's Avatar
2015ram
ok, i'll check it tomorrow,thanks
Old Feb 4, 2015 | 10:01 AM
gertie240's Avatar
gertie240
Also make sure the PCM has all of the plugs in good. I like to use a little dialectric grease on any connector I take apart. Also there are a couple grounds on the passenger side, one right by the computer.
