Tire Question, Need Help, Restoring 2000 Dodge.
Old Feb 10, 2015 | 07:59 PM
ryanblake's Avatar
ryanblake
Default Tire Question, Need Help, Restoring 2000 Dodge.
Down to the point. I have decided to restore a 2000 Dodge Quad Cab 1500 Gas Hog.
I am looking to fit the biggest tires possible on the stock 16 inch rims.
I am new to pickups, and the pickup is lower in the front than in the back. What would I need to buy in order to lift it up and make the pickup level? I am looking at anywhere between a 3 and 6 inch lift, what else is required or should be considered when adding a lift and leveling the pickup?
Old Feb 10, 2015 | 08:25 PM
Good info on lifts and tires in the FAQ/DIY section. Start reading. Also check the plenum. Welcome to the forum.
Old Feb 10, 2015 | 08:29 PM
ryanblake's Avatar
ryanblake
I definitely did read the FAQ/INFO forums, athough I couldn't quite find a DIRECT answer to my question about the tires.
What is the plenum?
Old Feb 10, 2015 | 08:31 PM
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Feb 10, 2015 | 08:36 PM
ryanblake's Avatar
ryanblake
Why did you have to point me towards the Plenum thread? Now I feel as if I need to replace my plenum gasket >_<
Old Feb 10, 2015 | 08:50 PM
You probably do.
The largest tires without lift? You *might* be able to fit 33's under there, with just a 2" leveling kit. Any bigger, and you will need a lift.
Old Feb 10, 2015 | 09:23 PM
Maintenance before mods.
Old Feb 10, 2015 | 09:34 PM
True that. But, if the tires that are on there are worn out......
Old Feb 10, 2015 | 09:44 PM
Ram Driver's Avatar
Ram Driver
^^ This First for sure ^^
After you get the truck completely mechanically sound, then start adding the mods you want.
I also have a 2000 Dodge quad cab that I`ve been working on for the last two years. The previous owner did nothing to take care of it, and everything was worn out from the ground up.
Old Feb 10, 2015 | 09:53 PM
Yep.....should have said maintenance and safety first....brakes, tires, etc.
