Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd Gen how to repair dash indicator
Step by step instructions for the do-it-yourself repairs.
Shift indicator adjustment
Aloha Friday to all,
I can't seem to take up the slack on the cable with the adjusting wheel for the shift indicator. I have the plastic clip on the steering column secured and I'm sure it's on correctly, but I think I'm missing something. Is there a rubber grommet that slips over the arm where the cable attaches? Any ideas what I might be missing? Pictures would help.
Thanks
Thanks
If you don't have one already, download the appropriate service manual for your year truck from this thread. Procedure for adjusting it is in there, and, some good pics.
Thanks Hey, I looked there and will try again. Ill have to expand my search, I might be looking in the wrong section.
On another note, that service manual really helped me figure out my IOD problem with the SBCM drain. I didn't realize the electric lock circuit plays an important role in the BCM timing system. Aloha
On my 1998 i took the lower dash panel off below the steering wheel and there was a white **** next to the steering column that turned both ways to line up the gear indicator, it should take up some slack. There is a write up in the faq/diy/ how to section called DIY - dashboard gear indicator fix.
