Pass side lower control arm braket broke
Old Feb 20, 2015 | 03:45 PM
Mygoldn's Avatar
Mygoldn
Default Pass side lower control arm braket broke
So fixed one problem to find a new one. Where the lower control arm attaches to the front axle on the bottom broke. I'm not sure what to do. I would assume to fix this I need a whole new from axle. Any ideas?
Old Feb 20, 2015 | 03:59 PM
Weld on a new mount?
Old Feb 20, 2015 | 04:03 PM
Mygoldn's Avatar
Mygoldn
I tryed welding the old one but it was to rusty and broke again on my first drive. Is that somthing they sell? And I could have to grind off the old one right? Is that safe to weld and grind on the axle
Old Feb 20, 2015 | 04:17 PM
Mygoldn's Avatar
Mygoldn
Any idea what will happen if I don't fix it right away and drive it till it's warmer out?
Old Feb 20, 2015 | 04:26 PM
You run the risk of tossing your front axle. Carnage ensues. It is NOT safe to drive that way. Not to mention the possibility of your truck trying to use that control arm to pole vault with..... that wouldn't be fun either.
Might pick up some scrap steel, cut yourself a couple brackets that go all the way from top to bottom, and weld that on.....
Old Feb 20, 2015 | 04:35 PM
Mygoldn's Avatar
Mygoldn
Oh. I guess I have another day of laying in the snow at -10 out : ). You think some big u bolts and some good metal I could go right around the axle? Have you ever seen this done?
Old Feb 20, 2015 | 04:40 PM
Ouch, that truly sucks. I hate working outside when it is incredibly cold out......
What I have seen is some of the lift kits that use brackets to move the control arm mounts. Something along those lines, that keep you in the stock location I think would be better....... If you have to pass any kind of safety inspection there, I doubt the U-bolt trick would pass...... That, and you really DON'T want to find out that it won't work, by having it fail while you are driving it.
Yes, I am paranoid.
Old Feb 20, 2015 | 04:44 PM
Mygoldn's Avatar
Mygoldn
So try and make one like what's already there and just grind off the old one? And weld the new one on. I'm not a great welder but I can weld ok. And my welder is the cheap one
Old Feb 20, 2015 | 04:46 PM
Pretty much, I would leave some of the good metal (if any) so you have something to keep things lined up, and to weld to..... Doesn't matter if your welds are pretty, so long as they will hold. Make sure you get good penetration on the welds.
Old Feb 20, 2015 | 04:48 PM
Mygoldn's Avatar
Mygoldn
Ok. Thanks. Il have to see what I can do
