Prepping for Plenum fix/tune-up, do I have it all?
Old 02-26-2015, 02:13 PM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
1997JollyGreenGiant is offline
Originally Posted by onegoodmason
Your so close to doing the t-chain it's almost irresistible . I doubt the chain is overly stretched , but , that damn timing cover gasket is prone to leak . Yeah , the balancer has to be removed , but , Most 5.9's at that K need or have new ones . Visually , the seal in the damper starts coming out and you may see some oil at the crank seal , with the engine running , it would wobble . You need to look at it from a side angle . Have a look at it as well . Both are common issues so catch it now if it needs doing , and you're right there !
Wow! I've got 190k on my 5.9's Harmonic Balancer, and I didn't think to look at it when I did my Timing Chain, but yeah, it wobbles. I was wondering why it did that. I'll look into replacing mine. Great Tip!
Old 02-26-2015, 04:50 PM
Moparite's Avatar
Moparite
Moparite is offline
Hay why not rebuild the whole motor! LOL If it's a daily driver and you have the time to do it by all means do it. But you don't need to go overboard.
Old 02-27-2015, 01:12 AM
bjpomeroy's Avatar
bjpomeroy
bjpomeroy is offline
I would be careful with the harmonic balancer. I have heard horror stories about guys changing them out with new ones and having issues because the new balancer wasn't balanced like the old one. A mechanic friend who rebuilds engines role me that he rebalances a new harmonic balancer to match the old one before he puts them on. He says a gram in the wrong place can cause issues. I'm not a mechanic so I can't speak to this beyond what I was told. My .2
Old 02-27-2015, 06:37 AM
1997JollyGreenGiant
Alright. I'll give my machine shop a call and see what they say.
Are the harmonic balancers balanced to a specific crankshaft? I have a spare Harmonic Balancer off another Dodge Ram, same year and engine. The rubber on it is coming apart. If I have that re-balanced, would that work, or should I use the one that's currently on my truck?
Just thinking that having the spare one rebalanced makes it easier when I swap it out.
Old 02-27-2015, 09:46 AM
bjpomeroy's Avatar
bjpomeroy
Definitely call the machine shop and see what they say. It never hurts to have too much information. If and when I replace mine I will have it balanced to match the original. Not sure about cost or anything, but I trust my friend who has been rebuilding engines for 30+ years. Other than that I don't know a lot about the process.
Old 02-27-2015, 10:10 AM
1997JollyGreenGiant
I called my machinist, he suggested I replace it with a new one. He'll have one for me this afternoon.
Old 02-27-2015, 10:15 AM
schmidtp's Avatar
schmidtp
schmidtp is offline
Maybe someday! I just wanted to get some of the known weak points done so it can be trust worthy for being used as a work truck. In the winter I drive it more than my car, but I am sure once it gets nice out it will only really be driven for camping, tailgating, and hauling.
Also, another question for all of you. Where should I look to order all of this? Other than the Hughes plate should I just do all of it off RockAuto?
Old 02-27-2015, 02:03 PM
ryan0714's Avatar
ryan0714
ryan0714 is offline
i live by rockauto man. cant beat it
Old 02-27-2015, 08:05 PM
onegoodmason's Avatar
onegoodmason
onegoodmason is offline
x2 , hard to beat rockauto
Old 02-28-2015, 02:12 PM
Moparite's Avatar
Moparite
Moparite is offline
Prices are hard to beat but some parts you will pay more to ship them. Look around for discount codes. Shop wisely.
Quick Reply: Prepping for Plenum fix/tune-up, do I have it all?
