New tires help!!! 35,s???
Old Feb 25, 2015 | 05:55 PM
Mxrider987's Avatar
Mxrider987
Exclamation New tires help!!! 35,s???
1500 Laramie 2.5 leveling kit on factory suspension blocks. Has anyone ran 325/75r16 for tires? Any cutting. Spacers?!? Need some help
Old Feb 25, 2015 | 06:07 PM
ryan0714's Avatar
ryan0714
i think the most people have ran with a 2.5" spacer on the front is 315s, you might run into some rubbin, you gonna have the stock backspacing or are you gettin new rims?
Old Feb 25, 2015 | 08:28 PM
Even 315's on 2.5" lift are gonna hit in several places...... If you don't wanna spend more on a lift, go with 285's, or, get at least 5" of lift.
Old Feb 25, 2015 | 08:35 PM
Mxrider987's Avatar
Mxrider987
I figured I might do some rubbing I'm not going to be blown away if it does happen. It's a tall truck as it sits so I figured why not. I want more lift but cant afford the down time. So just the tires for now. I might do wheel spacers if need be
Old Feb 25, 2015 | 09:57 PM
dean98ram1500's Avatar
dean98ram1500
You could probably run those width of tires with the leveling kit, but the key will be to get rims that are like 12" wide with a huge offset to keep them from rubbing on the fender/control arms.
