Tranny being weird
Old Mar 4, 2015 | 01:08 AM
zildjian3707's Avatar
zildjian3707
Default Tranny being weird
tranny was rebuilt before i bought it but anyway, i replaced the governor pressure sensor and solenoid on it about 10k ago. Anyway as of late it shifts fine and down shifts fine. Its always starting in 1st like normal. However if i accelerate slowly it shifts like a dream from a stop, but if i accelerate faster like from a stop on to the freeway or anywhere with purpose it seems to hiccup and slip and catch itself all the way through third. It doesnt do it everytime but it clearly just doesnt like fast acceleration as of late. Im thinking maybe throttle position sensor? also it seems that these days i have to slam my throttle down to get it into overdrive on a hill.
Old Mar 4, 2015 | 01:24 AM
horatio102's Avatar
horatio102
Slip is bad. Applying more torque than the trans is willing to hold now? Last trans service/band adjustment?
Old Mar 4, 2015 | 02:00 AM
zildjian3707
not sure on the band adjustment. fluid and filter are 10k old still really clean
Old Mar 4, 2015 | 05:51 PM
Moparite's Avatar
Moparite
Check the TV cable, sounds like it's out of adjustment.
Old Mar 4, 2015 | 05:56 PM
UnregisteredUser's Avatar
UnregisteredUser
My money would be on the governor pressure sensor. If the TV cable is adjusted properly, you might want to look into that.
Old Mar 4, 2015 | 09:22 PM
zildjian3707
the gps is was replace not to long ago. where is the cable? im not too familiar with transmission and i dont wanna **** with anything to tricky
Old Mar 4, 2015 | 09:28 PM
Goes from passenger side of throttle body, down around the trans, and then back to where the shift linkage hits the trans. You want zero slack in the cable, and it should not be pulling at all with the throttle closed. Procedure for adjustment is in the service manual. It's not complicated. If you have a friend to help, you can do it in about ten minutes.
Old Mar 6, 2015 | 02:12 AM
zildjian3707
k ya ill adjust that cable this weekend. Its a rebuilt tranny, i cant imagine it ****ting out of me this early on. They might have not adjusted it when they did the rebuild, but ill go ahead and do it. So basically when looking at the cable, i just want it to be perfectly straight with no play or is there a better way of going about it?
Old Mar 6, 2015 | 11:34 PM
ReadRam's Avatar
ReadRam
Be careful you don't break the locking tabs while removing the white clip that is necessary to make cable adjustments. Throttle cable and TV cable should move at the same time, so it's easier to have friend help. Look at the service manual for more specific instruction.
When driving in a lot of hills you could just drive with OD off.
Old Mar 7, 2015 | 01:21 AM
zildjian3707
o/d off on hills huh, wont i go like 30 up the whole thing then instead of like 40ish
