Looking for transcase 47RE
#21
It's just as i stated earlier, It's the overrunning clutch. It may look like a bearing but it is a lot of rollers and springs. I had one of these go in a 727. It cracked the housing similar to yours. If you are not familiar the new style transmissions are based of the 727 so it looks very similar. There are aftermarket ones that bolt in and are stronger than the press in style that Chrysler used. I dont think you can use that style on yours because it looks pretty bad. Hope you can find one.
This is a bolt in one, See the bolt holes.
#22
So it is called an overrunning clutch? I thought it was a bearing, as you said, it looks just like one. Yeah the repairkit he ordered from usa was a bolt in one. And he said that if often looks worse than it is So when i showed him these pictures of the cracks he said that it was not a problem.
Anyway, i cant wait to drive it again!
#23
#24
Yes, this one is going in the trash since he couldn't fix it and I can't sell it. Well, hopefully i have found one now (horatios).
But i don't know if i'm going to put a bolt in clutch in it since it costs about $450 to get it done.
The guy who's gonna put together the gearbox said that the clutch breaks when you put in reverse while still going forward.
#25
Well it's a weak point never the less. I never priced them but i don't see it being that much. Will be a bit more labor to one in. I'll look around an see it i can get some prices. If you can get it along with the case the builder might give you a break on the price to put it all together. Take your old case to a scrap yard. You will get a few bucks for it. Not sure how many of them are in Sweden.
#26
Thanks! We have some scrap yards but then i'll have to freight it back to me which costs about $60, and then i think i have lost more than i can sell it for here, unfortunetly, but thanks for the tip anyway.
#27
#28
I would, however, need that gearwheel that is in the rear axle, ABS trigger, do you know which one i mean, sorry for being a little unclear.
And the female part for the belt clicker on the drivers seat.
Have any of those?
#29
