Auto-transmission swap 5.9 2wd 1996 to 1997 connections questions
Old Mar 13, 2015 | 01:45 PM
keepseln's Avatar
keepseln
I will look for it when I get home. On another note, the existing trans gives a very inaccurate speed to the dash. Could that be a bad VSS?
Old Mar 13, 2015 | 07:00 PM
Could be. If anyone made changes to the driveline over the years though.... and didn't compensate for them.... that might be the problem too.
Old Mar 14, 2015 | 01:16 PM
keepseln's Avatar
keepseln
I'm an *** sorry for wasting everyone's time. I could have sworn my other truck was a '97. But after following some advice and looking at the casting stamp it could not have been.
Crazy thing is I've been sitting on this trans for years waiting on a problem with my '96. So I have a '98ish rebuilt trans for sale if anyone is interested.
Old Mar 14, 2015 | 01:17 PM
keepseln's Avatar
keepseln
I would like to explore why my speedo is off. Can I adjust the VSS or does it need to be replaced?
Old Mar 14, 2015 | 04:55 PM
On the 96, VSS is gear driven. Need to see what size tires you have, and what gear ratio you have in the diffs, then there is a cool chart to tell you what color driven gear you need, to have your speedo be accurate.
Old Mar 15, 2015 | 11:08 AM
keepseln's Avatar
keepseln
well the tires are 275/70R17 how would I confirm the gear ratio?
Old Mar 15, 2015 | 11:22 AM
Moparite's Avatar
Moparite
Tag on rear or look at the sheet under the hood.
Old Mar 15, 2015 | 12:17 PM
keepseln's Avatar
keepseln
Thanks,
Looks like 3.92 - 275/70R17
