Issues with starting.
Old Mar 12, 2015 | 11:46 PM
joshbart92's Avatar
joshbart92
Default Issues with starting.
I was coming into my work parking lot, put the truck in reverse and backep up then put it in park. Then the truck died. I went to go start it again and the only thing that works is the cluster lights, cab lights, blower motor and headlights. My odometer and radio do not work. So I tried putting the truck into neutral and wiggling it back and forth. When I did that the truck dash information light would show up and I could start it. I drove it home and backed up, put it into park shut if off. Then it wouldnt start back up. Help please
Old Mar 13, 2015 | 09:48 AM
Check your batter terminals, make sure they are clean and tight.
Will the engine crank when things are being odd?
