trouble after plenum gasket replacement
Old Mar 16, 2015 | 11:12 AM
Ham Bone's Avatar
Ham Bone
I have the opposite problem of not being able to get my truck completely up to temp
Old Mar 16, 2015 | 11:29 AM
Originally Posted by CPTAFW163
Yup, when I took out the old sensor, it came apart. They are very fragile.
When I am "burping" the system I drive my truck up my "oil change ramps" so the radiator top is higher than the heater core. You will notice that the heater core intake lines (left side of firewall) are higher than the radiator spout. That means air will get trapped in there unless you raise the front of the vehicle.
You can try the ramps, open the rad cap and start the truck. As it gets warm, the air will burp out.
I am running a 180* t-stat, and my truck runs very cool. These trucks actually run very cool when the air is out, unless the TRANNY is getting hot. The tranny fluid will raise the fluid in the radiator. Dodge knew this for towing purposes and installed the external tranny cooler to take some heat out of the tube in the radiator.
Wow. Nice to see you again! I've missed you.
Old Mar 16, 2015 | 11:09 PM
2damnyankee's Avatar
2damnyankee
Originally Posted by bigred95
I replaced the sensor, still the same thing. On the highway it reads normal temperature, but in the city it jumps between what I'm assuming 180 and 220, and its only 35 degrees out. If i get on iit, it cools down. The water pump was replaced a couple months ago, and i did not replace the thermostat, which i am thinking is the culprit, but I'm not sure. It never fluctuated like this before. I also suspect the water pump, although it was replaced recently
if it cools down when i punch it, like i said, normal temps on the highway.
If you have to jump on the gas to cool it down some, then that tells me that the clutch on the fan is shot, replace the fan and your worries should be over. Moderate 35 degrees one way or the other means the fan is locking up and unlocking
Old Mar 16, 2015 | 11:25 PM
bigred95's Avatar
bigred95
Well guys, waste of a thread �� i suspected thermostat, so i replaced with a 195 stant superstat, guess who put the thermostat in upside down when i put the manifold back on... All is fine now. It's the little things that always bite you in the a*s! Thanks for the replies guys, but as always it's just me doing something stupid ��
Old Mar 17, 2015 | 09:24 AM
whitesquirrel45's Avatar
whitesquirrel45
Stick around for awhile and I'm sure you'll get your chance to see me do several dumb things!
Old Mar 17, 2015 | 10:24 AM
bigred95's Avatar
bigred95
Smile
My guess would be stuck open thermostat, or the frozen fan clutch as previously stated, but i don't know if i would listen to me since i put mine in backwards
Old Mar 20, 2015 | 11:27 PM
BrandonBuc'em's Avatar
BrandonBuc'em
not to hijack this thread or anything but, what are signs of a failing water pump?
i have a stinky smell of coolant up front, there are no visible leaks that i can see. but i smell it. anyone?
Old Mar 21, 2015 | 10:09 AM
Coolant loss is the biggest one. But, if it were the pump, you would be able to see evidence of it.
Another is rude noises. Make sure that it is indeed the pump before you throw money at it though.
Old Mar 21, 2015 | 10:43 AM
Moparite's Avatar
Moparite
Look under the pump for the hole in the bottom(between the bearings). Usually the first place you will see it start to leak from.
Old Apr 8, 2015 | 08:16 AM
BrandonBuc'em
She's not leaking... But I smell that bitter sweat coolant smell when I walk around the front as its running. I notice it most when it's warming up to operating temperature... Like when I get up in the morning stop at the store and walking by it I smell it. It's not like whooooah but coolant has a very sweet scent so it's easily identified
