fog lamps
Old Mar 16, 2015 | 02:43 PM
horace's Avatar
horace
Default fog lamps
I been thinking of trying to get my fog lamps working on my 97 Laramie, are they on a fuse? Any trouble shooting suggestions? thank you
Old Mar 16, 2015 | 02:58 PM
If they dont work, fuse sounds like a good place to start.
Old Mar 16, 2015 | 08:16 PM
Torxhead's Avatar
Torxhead
There should be a 5 amp fuse for the illumination circuit which includes cluster,HVAC,fog switch,radio, and overhead console.
Old Mar 17, 2015 | 12:42 PM
armynurse's Avatar
armynurse
There are also two relays for the foglights under the hood in the plastic box on the driver's side (relays made by Hella actually).
And if I remember right the headlights have to be on (low beam) for the foglights to work (so make sure you've got your headlights on when checking them).
Old Mar 18, 2015 | 07:24 AM
webhead68's Avatar
webhead68
Mine don't work either but my button does not even light up to begin with it does on my Wife's Durango so I assume it does on the RAM. Probably going to tear into the wiring this weekend.
