Trouble starting and staying started
Old Mar 17, 2015 | 10:41 AM
ngmillar's Avatar
ngmillar
Default Trouble starting and staying started
2001 Ram 1500 5.9 217k miles...Basically the truck has been sitting a few months after it stopped running I try to start it from time to time but its been needing a jump every time and even then its really hard to start. After getting it started the only way it will idle is if I keep my foot on the gas for maybe 10 mins then it will finally idle on its own. Then if I try to move it the truck won't make it out of the drive way without dying. I have another car so I haven't worried about it but I'm looking to sell the truck and id like to sell it running if it isn't gonna cost an arm and a leg to fix. Also the truck won't start after it dies. I can only assume the alternator is bad and possible the CPS.
Old Mar 17, 2015 | 11:00 AM
Moparite's Avatar
Moparite
Did you fix this issue?
Old Mar 17, 2015 | 11:15 AM
But a good charge on the battery, and see if that doesn't improve its attitude some. The electrical on these trucks gets strange with a low battery.
Old Mar 17, 2015 | 02:39 PM
D_Man_2001's Avatar
D_Man_2001
New Member
Default Throttle position sensor.
I have a 2001 dodge ram 5.9 150k miles, and it did the same thing and it was the Throttle position sensor
Old Mar 17, 2015 | 02:52 PM
ngmillar's Avatar
ngmillar
Yea I've seen some crazy things happen to my truck when my battery was dying so this is where it gets weird after I charged it all the way up it still wouldn't start unless I jumped it and the battery is less than a year old and tested good I mean should I try new cable connections ?
Old Mar 17, 2015 | 02:53 PM
ngmillar's Avatar
ngmillar
Interesting I'll look in to it thanks
ngmillar's Avatar
ngmillar
When I say stopped running I'm referring to the starting issues Im having...
Old Mar 17, 2015 | 06:11 PM
Clean the battery terminals good. Shouldn't need a jump to start with a charged battery. Does it roll over slow, or just not wanna fire?
Old Mar 18, 2015 | 09:31 AM
ngmillar's Avatar
ngmillar
OK well I changed the TPS and got it jumped again and it ran and drove a little but cut it off and wouldn't start. Turn the key and it clicks a couple times then nothing the battery is a year old so it should be good but I think I'm gonna have it checked again cause even after a good charge I still had to jump the truck
Old Mar 18, 2015 | 10:01 AM
If the battery froze, it is more than likely toast.
