Finished 5.9 swap questions
Old Mar 23, 2015 | 10:09 PM
tweeker909's Avatar
tweeker909
Originally Posted by 95Erokram
Ok so of course I bought a Hughes plenum plate when the 360 donor was overhauled. My guess exactly that the 318 pcm wasent giving enough fuel under heavy acceleration. I really don't think I'll go to obdII. The 94-95 mopar 5.9 pcm will work but will octane boost every fill up hurt? We have 90 as premium here. Also what about having b&g flash for a mild 360. And the backfire is actually 45-55 and feels like the header meets the y pipe area. Maybe my exhaust has too much back pressure or too little? Thanks for the replies!
your all ready running a mp pcm via your sig and paying for the good stuff. camming a motor and not wanting to pay for the good stuff dont go together. howz about some pics of all that work to share
Old Mar 24, 2015 | 12:27 PM
95Erokram's Avatar
95Erokram
I lost that mopar pcm more than a year ago. I'm running my oem pcm. it somehow disappeared between addresses. I'll remove that from my sig soon enough. Good spot. My previous comments I believe stated factory. Currently I'm running 90 just because it's running smoother at this moment. Still stock 318 pcm with a cammed 360 and full bolt ons. I could put a couple pics of the finished product but don't really have any "in the process" pics.
Old Mar 24, 2015 | 12:35 PM
snowboundrmk's Avatar
snowboundrmk
Get the Mopar pcm and check your fuel sync.
Old Mar 24, 2015 | 07:45 PM
95Erokram's Avatar
95Erokram
I will look into the mopar pcm for a 5.9L. I was just worried about octane boost with mmt every fill up for years to come as a detriment to my engine. Nobody has told me otherwise so Im guessing its fine.
Old Mar 24, 2015 | 09:01 PM
snowboundrmk
You would probably be fine just running the 90 pump gas. I run mine with 91 and have had no problems.
Old Mar 25, 2015 | 03:20 AM
95Erokram's Avatar
95Erokram
Good to know. I've ordered a mopar perf pcm for the 5.9. I'm assuming the harnesses fit just the same for 94-95 auto. I reset my pcm by removing the negative cable and it runs a bit better so the 5.2 pcm is simply trying but cannot supply the necessary fuel. Also I think my fuel pump is running 38-39 psi. I believe that's below the min threshold. Something I might need to look into. Thanks for the input. I've also got to realize I have only 800 miles on the fresh 360 so it's still breaking in.
Old Mar 25, 2015 | 09:12 AM
snowboundrmk
That fuel pressure is good. The ob2 trucks run slightly higher at I think 43psi.
Old Mar 25, 2015 | 03:41 PM
95Erokram's Avatar
95Erokram
Ok thanks
Old Mar 25, 2015 | 06:28 PM
Ok thanks
49 PSI for OBDII trucks.
Old Mar 26, 2015 | 05:08 PM
tweeker909's Avatar
tweeker909
How do you really know if your running lean or rich without a wideband or dyno run. Speculation at this point. I agree with snowbound mp pcm set sync. Sync set to far negative will cause backfire stumble host of other issues b/c injector is fired to soon. Adv sync causes no ill affect other then not starting if to far adv but so will retarding the sync. Can go to a larger injector but doubt it needs it. Oem are 24.5 at 39psi.
