Finished 5.9 swap questions
How do you really know if your running lean or rich without a wideband or dyno run. Speculation at this point. I agree with snowbound mp pcm set sync. Sync set to far negative will cause backfire stumble host of other issues b/c injector is fired to soon. Adv sync causes no ill affect other then not starting if to far adv but so will retarding the sync. Can go to a larger injector but doubt it needs it. Oem are 24.5 at 39psi.
Also alaska doesn't really have much of a dyno here. Thanks all for the replies. I think the backfire was partly from heavy throttle and dropping a gear. It hesitated and then would go. Almost like a really bad detonation except it's a backfire around the header collector location. When I say lean I mean 75% or more "go pedal". My shift points have much improved as well since using a correct pcm for the swapped motor... Performance or not. I'm intrigued by this fuel sync though..
Okay. That has been done. I watched him explain the process with the old 318. Good to know though. Truck runs good and successful swap so thanks again guys!
