Steering issues
EDITED TO ADD: If the brakes drag only after they've been used hard there may be water in the brake fluid that can boil and the resulting gas pressure can cause them to drag. That's an easy fix, just bleed the system.
Rear brakes don't often drag without a foot on the pedal to cause it.
Supposedly the guy I bought the truck from did all new brake parts. Not sure if he did calipers too but I can look and find out. I did notice I hear a grinding noise from the rear when driving at low speeds. But that has done that from the day I got it about a year ago. It's a plow/work truck so I assumed it had some sort of issue but never really looked to far into it.
When I got my truck I was having the same exact problems as you are having with your truck, because the previous owner did nothing to take care of the truck.
If I hit even the smallest bump in the road my truck would move half a lane in either direction, and on a straight flat road it would wonder all over the road.
I had a shop go through everything, and they ended up replacing the brake pads front and rear, new front brake calipers, new shocks, all new tie rods, new track bar, new ball joints, new hubs, new steering box. Now all I need is new tires.
So, it sounds like your truck is in need of some front end and brake work to get it back into shape. If you can do the work your self, that will save you some money, you just need to get the parts.
I ended up ordering new rotors and all new tierods from rock auto. Hopefully this will help my issues. Had a buddy of mine look at my trucks and he thinks if I start with that it should help. Next will be a new steering box and a few new lines. He also noticed my front spring perches are rotted out. Anyone have any experience with these?
