Leaf Spring Hanger
Old Apr 11, 2015 | 10:04 PM
BADDBOYY21's Avatar
BADDBOYY21
Default Leaf Spring Hanger
I need to replace the rear leaf spring hanger on my 2500.
I'm guessing I will have to grind off the heads of the rivets on the old one. I assume I will have to use bolts to install the new one. Does anyone know what grade and size bolts I will need to get?
Has anyone done this? Any tips or advice?
Old Apr 11, 2015 | 10:42 PM
Ram Driver's Avatar
Ram Driver
You want to use at least grade 8 bolts. Not sure of the size.
Old Apr 12, 2015 | 08:57 AM
jrox44's Avatar
jrox44
I've never had good luck getting shackle bolts out. Usually had to torch the bolt out. But its possible with a Big hammer, big impact driver, lots of heat and muscle. Start spraying the bolt down acouple times a day with PB blaster for about a week and it makes the Job 100 times easier when your ready to do it.
Old Apr 12, 2015 | 02:54 PM
BADDBOYY21's Avatar
BADDBOYY21
I have already removed the shackles. I am replacing the actual spring hanger that's on the frame.
Old Apr 12, 2015 | 03:08 PM
Got the new bracket? Yep, grind off the rivets, get some appropriate size grade-8 hardware, and bolt 'em back on.
Old Apr 12, 2015 | 03:12 PM
BADDBOYY21's Avatar
BADDBOYY21
I don't have the bracket yet. I will attempting to get one at my local Dodge dealer. If they don't have one or it is way over priced, LMC Truck has them for about $85.
