reverse lights
A common problem with manual trans.. I've got a 2001, does the same as yours. The reverse light switch plugs into the trans. and the internal switch actuator wears to a point where it can't actuate switch. Some have added manual switch to dash to activate reverse lights.
ORIGINAL: jrmcx
mine has the same problem sometimes. try moving the stick side to side when its in reverse. maybe it will come on then. i have to hold the stick to the side sometimes to get it to work.
Trending Topics
Currently my entire life BLOWS so I look at the BU light problem as a little breeze. In the spring I'm thinking about riging a set of driving lights to the *** end of the truck along with one of those pimpy back up "dingers" since I nearly backed over a couple of rugrats on separate occasions this summer.
