1998 PU w/318 fuel flooding
Old Apr 29, 2015 | 10:17 AM
donparadowski's Avatar
donparadowski
Default 1998 PU w/318 fuel flooding
I have a fuel flooding issue. Mileage is down to 7.3 mpg. I have black soot in the tail pipe, with grey smoke coming out. Cylinders 7 &8 frequently foul with fuel deposits every 3-4 tank fulls. There is a slight to moderate power loss going on proportional to the amount of deposits on the spark plug’s ceramic. It has a fresh and complete tune done properly. My motor is equipped with throttle base injection. The problem is I can’t find the cause of the flooding issue. I can also be reached directly at donparadowski@yahoo.com
Old Apr 29, 2015 | 10:20 AM
schmidtp's Avatar
schmidtp
What was all replaced during the tuneup?
Old Apr 29, 2015 | 06:39 PM
Should be multi-port fuel injection.....
How is your temp gauge behaving? CEL on? Have you fixed the plenum yet?
Old Apr 30, 2015 | 10:18 AM
donparadowski
@ schmidtp
Plugs, wires, cap, rotor, timed, & engine oil.
@ HeyYou
Temp gauge is doing fine around 190F. No to the plenum chamber. How does one fix a plenum? CEL ! ! ! The idiot light? Are you talking about the “check engine” light? If so, yes but it keeps coming back on.
Don
Old Apr 30, 2015 | 10:41 AM
schmidtp's Avatar
schmidtp
This may be your problem.
https://dodgeforum.com/forum/2nd-gen...um-thread.html
You can check to see how bad it is by taking your intake off, opening up the throttle body, and looking down into with a flashlight. If it is full of oil the plenum needs to be replaced.
Old Apr 30, 2015 | 01:41 PM
TiminSoCal's Avatar
TiminSoCal
What do you mean when you say
You timed it?
Distributor controls fuel sync.
PCM does timeing.
If you turned the distributor that is
probably your problem.
Old May 1, 2015 | 09:20 AM
Moparite's Avatar
Moparite
I think you have a bad injector/s. Get the fuel pressure tested and see how fast it drops when the pump is off.
