AC Blowing hot air.
Old Apr 30, 2015 | 10:20 AM
PaulMcKIII's Avatar
PaulMcKIII
Default AC Blowing hot air.
So I did a search and found no topics on this.
For any michiganders you remember the bitter winter we had. Well I had my heater core replaced mid winter. now with the weather warmkng up i am trying my ac. Only problem is that my ac blows hot air. I tried recharging my ac but it is not needed. My compressor is running but the vents only blow hot air. Can some one help me figure out what could be the problem.
Old Apr 30, 2015 | 12:35 PM
What are the pressures? Who recharged it? Did it work last summer? Could be a blend door issue as well if they had the dash off to replace the heater core.
Old Apr 30, 2015 | 12:41 PM
PaulMcKIII's Avatar
PaulMcKIII
It did work last summer. And they did have to remove the dash to replace the heater core.
*I will get the preasure when I get home from work.
Old Apr 30, 2015 | 06:24 PM
What year is your truck?
Old May 1, 2015 | 06:53 AM
PaulMcKIII's Avatar
PaulMcKIII
Old May 1, 2015 | 08:45 AM
Moparite's Avatar
Moparite
Was the ac/heater box completely removed? You can get the heater core with the bendable lines so it can be installed with out removing it. If you get the oem style you need to completely remove the box(ac charge will be lost and it will need to be recharged). Feel the metal refrigerant lines going in to the cab, If they are not that cold it may have a week charge. If it is ice cold your problem is the blend door.
Old May 1, 2015 | 03:01 PM
PaulMcKIII's Avatar
PaulMcKIII
The preasure in the linewas 40 psi. I did feel the refrigerant line and it was extremely cold. Bext question is how do i repaor this or how much will it cost me.
Old May 1, 2015 | 07:33 PM
rjb700's Avatar
rjb700
Default blend door
http://www.heatertreater.net/magento...ram-95-02.html
more info about the blend door here.
Don't have any experience with the company though
2001 5.9 1500 4x4 qc short bed ... also non working ac
Old May 1, 2015 | 09:33 PM
That only applies to 2000 and up trucks. Older guys use a cable.
Old May 2, 2015 | 12:06 PM
Moparite's Avatar
Moparite
Yea there is a cable the runs from the **** to the the blend door. Might want to take a look and see if it's hooked up and working. The blend door is about the middle of the dash to the right of the stereo on top of the ac/heater box(if i recall).
